Hi Ravinder,
Thanks for the reply.
Unfortunately they aren't ( though I didnt know that would cause the others to terminate anyways , so thats good to know, thanks! ), it happens when they are run manually.
From research, it seems actions like ""Activate"" hand over to the application to be activated then blue prism waits for a response back, so it would appear the applications are either no passing a response back, or Blue Prism isn't picking up the response, but knowing this, doesn't leave us with anyway of fixing it, as our version Blue Prism doesn't support the timeout feature.
