Resource PC HTTP Interface for SSO e.g. UserList or ProcList
Simon_AndrePede
I'm trying to simply call the function
http://localhost:8181/user%20name%20 [username] &password%20 [password] &userlist
or
http://localhost:8181/user%20 [userID] &password%20 [password] &userlist
This naturally works perfectly fine using a non SSO environment.
however, now i'm moving to a SSO environment, and got difficulties authenticating these type of calls through HTTP.
so what would be the equivalent to above for SSO?
my domain is something like: companyAD.woop.com
username is RobotAwesomeUser1
password is SoSecurePassword
user principal name becomes RobotAwesomeUser1@companyAD.woop.com
I thought the http call would be:
http://localhost:8181/user%20name%20 [user principal name] &password%20 [password] &userlist
Regards, and thanks for the help
Simon Andre Pedersen
Senior Associate
PWC
Asia/Hong_Kong
Best Answers
I managed to solve the issue. It was rather stupid.
I tried replicate my issue using another environment also based on SSO.
this is the correct solution:
but you need to make sure that the password contain valid HTML Path characters. My password contained "#" ​which had to be translated to %23
then it worked just fine.
Senior Associate
PWC
Asia/Hong_Kong
5 REPLIES 5
Walter.Koller
Level 11
I was in contact with Blue Prism because of this exact question. Unfortunately HTTPs commands with SSO are not supported.
The alternative is to use CLI automatec.exe, which supports /sso switch.
I hope someone corrects me here and shows me another workaround or solution.
Walter Koller
Solution Manager
Europe/Vienna
Senior Associate
PWC
Asia/Hong_Kong
Hi Simon,
what Blue Prism version are you using?
I tried your proposed solution with v6.4 and it didnt work.
I tried:
http://<hostname>:8181/user%20name%20<user>@<domain>&password%20<password>&userlist
http://localhost:8181/user%20name%20<user>@<domain>&password%20<password>&userlist
http://localhost:8181/user%20name%20<user>&password%20<password>&userlist
User name, domain and password do not contain any special characters
I always receive:
USER SET
AUTHENTICATION FAILED
USER NOT SET
Walter Koller
Solution Manager
Europe/Vienna
I think what you are trying is correct. however, need to make sure the username is exactly as expected.
You can also try with using /user <userID>&password <password>&userlist
btw at my company the username will include spaces e.g. simon a pedersen@adgroupcompany
currently using 6.6, but testing on latest version of a 6.4 edition
Senior Associate
PWC
Asia/Hong_Kong
My user ID does not contain any special characters or blanks. The same with the name of the domain and the password. Although the password is case sensitive.
I have tried with log-on domain and AD host (same as used for configure Blue Prism SSO).
all without success though.
I hope I can manage to run some tests on a later version of Blue Prism later.
Walter Koller
Solution Manager
Europe/Vienna
