Rest API Call - 407 Authentication required
SHAHRULRIZALSAI
Hi Experts,
I had invoked restful API hosting in azure from Object and received below error.
Internal : Unexpected error Error during Web API HTTP Request
HTTP Status Code: 407
HTTP Response Content: <HTML><HEAD>
<TITLE>Access Denied</TITLE>
This is because, form our network it has to go through proxy authentication to access external URI.
If i am browse to any external website from resource PC, then i am able to proceed run the object and get the response content. otherwise it will return 407 error.
This issue because of calling an external URI require a proxy authentication. How to call a rest API with enter the proxy authentication?
SHAHRULRIZAL SAID
Best Answers
ewilson
The WebAPI feature of Blue Prism does not support proxy authentication. If the is a requirement there is a REST web service VBO available on the Digital Exchange that I believe supports this. If not, the alternative would be to use a code stage and invoke the .Net HttpWebClient object directly. With that, you can definitely set up proxy authentication.
ewilson
Hi Eric,
Thank you very much on your response.
Will do it via code stage.
SHAHRULRIZAL SAID
Hi Shah,
Were you able to handle the proxy authentication via code stage?
Aravinda Misra
Hi Aravindra,
Yes i had use it in code stage.
I am using below in code stage
HttpWebRequest request = (HttpWebRequest)WebRequest.Create("http://www.google.com");
IWebProxy proxy = request.Proxy;
string URI = string.Empty;
if (proxy != null)
URI = proxy.GetProxy(request.RequestUri).AbsoluteUri;
WebProxy myProxy = new WebProxy();
Uri newUri = new Uri(URI);
myProxy.Address = newUri;
myProxy.Credentials = new NetworkCredential(UserName, Password,"MyDomain");
request.Proxy = myProxy;
var client = new HttpClient();
var uri = "http://www.google.com";
var response = client.GetAsync(uri);
SHAHRULRIZAL SAID
