Sample Headers
Are Sample headers case sensitive?
Currently for a field "Ship To" I'm using Following 3 sample headers.
1.Ship To
2.ship to
3.SHIP TO
Also if the original field on invoice has special characters to it (e.g Ship To: xyz) then should I use "Ship To:" OR just "Ship To" is enough.
Just wanted to understand the right way of using it as good practice.
Thanks & Regards,
Tejaskumar Darji
joefarr
Hi Tejaskumar
It isn't case sensitive so all variances of "Ship To" should be recognized.
In respect of the special characters, I recommend including them as it enables you to select the entire fields and answer. Decipher will auto-remove the header from the result.
Hope this helps.
Joe Farr
Product Consultant
Blue Prism Limited
joefarr
Hi Tejaskumar
Hope this helps.
Joe Farr
Product Consultant
Blue Prism Limited
Thanks for bringing clarity on this one. Appreciate your help.
Thanks & Regards,
Tejaskumar Darji
