Sample Release files for 6.9 and 7.0 Blue Prism versions
16-09-22 12:53 PM
I need the release files of Blue Prism versions 6.9 and 7.0 for testing purpose. Can anyone please help to share it?
16-09-22 08:24 PM
Hi Selvalakshmi,
Could you be a little more specific about what you're requesting here? For example, are you requesting the v6.9/v7.0 installers for the Blue Prism product, or sample Process/Object release files?
The Product pages on our Portal contain the downloadable installers for all current and previous versions of the product:
Current release
Previous releases
Current release
Previous releases
19-09-22 06:39 AM
Hi Steve, Thanks for your response. I am looking for Process / Object release files.
19-09-22 02:27 PM
The "Developer Jumpstart" area of the 'Product' section on our Portal contains a few sample Processes and Objects that may be what you're looking for here. There are two Process Templates, a "Process Examples" release containing samples, and some Object Templates, all with accompanying documentation and relevant to v5/v6 (but will also work with v7).
19-09-22 03:15 PM
Hi Steve,
Thanks for your support
