Hi Magdalena,
It still works in 6.10.1, and I believe I've done that in 6.9 as well. What I suspect is that if you upgraded from a version below 6.6, then the XML is just different from what you were using before. You'll need to look at the new XML format and adjust your template XML before pasting in. The reason I suspect this is the issue is that Blue Prism will simply reject the paste if it is an invalid XML schema (that is, invalid from the perspective of using in a process/object).
Dave Morris
Cano Ai
Atlanta, GA
