Scheduling issue in Blue Prism 6.2
28-02-19 04:10 PM
I am facing issue with scheduler in Blue Prism 6.2 version.
My process must be executed daily 8pm to 8am.I have created a schedule.Scheduler is starting at that time but process is not running.It is showing the below error sometimes
"Task: New Schedule - New Task - Session creation failed on resource 'XXX': Failed to create session on XXX- Failed to get effective run mode - Unable to calculate run mode - object Blueprism.Automate.clsCredentialsActions does not"
sometimes "Task: New Schedule - New Task threw an exception: Resource XXX is offline - retried 10 times"
sometimes "Object reference is not set to an instance of an object"
Please help me.
25-03-19 04:13 PM
This issue was there in version 6.2 and is resolved in 6.2.1 as of now.
http://portal.blueprism.com/customer-support/support-center#/path/11713…
Ravinder Saini
08-05-19 07:36 PM
Hello:
I had the same issue. The way we solved it was connected all the Runtime Resources to the Blue Prism App Server instead of straight to the database.
Thanks.
Rayann Yassine
