Script to delete the existing connection mode (connection mode 0 = message level encryption)
Dylan
Hi there,
I've been tasked to:
  1. To create a script to delete the existing connection mode (connection mode 0 = message level encryption)
  2. To implement the below script, which creates a new connection using connection mode 0 (connection mode 0 = transport level encryption).
The script I've been give for number 2) is below:
Invoke-command {Start-process "<C:\Program Files\Blue Prism Limited\Blue Prism Automate\Automate.exe>" -verb RunAs -ArgumentList '/setbpserver "EXAMPLE SERVER NAME" "EXAMPLE PORT NUMBER" /connectionmode 1 /dbconname "BP_DEV"'}
However, I'm not quite sure how to script task 1.
I'd really appreciate any guidance,
Thanks!
Dylan
Dylan
NarayanShrawagi
Please can you elaborate on which connection you are talking about?  Is it application specific?  Are you using code stage in BP or you are using any external script?
Narayan Shrawagi
Senior Consultant
T systems India private limited
Narayan
