Hi Cynthia,
I recall these codes differ per emulator. The emulator we used before used different codes than the other brand we were supposed to migrate to - in the end we didn't.
The document with codes for each key can either be found in the documentation (Help menu) for your emulator or you can find it on the interweb.
Hope that helps...
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
