Spying body of email - gmail
02-08-17 11:39 AM
Multiple elements are highlighted. Hence cannot be identified on all modes.
05-03-20 11:00 PM
You can use Email-POP3/SMTP Blue Prism VBO for getting the gmail email, instead of spying.
The POP3/SMTP should provide you the capability to interact with POP3 and SMTP email protocols
More information is available here.
https://digitalexchange.blueprism.com/dx/entry/3439/solution/blue-prism-pop3smtp-utility
InJoe Khor
InJoe Khor
In Joe Khor
Sr. Product Consultant
06-03-20 04:38 PM
Hi Unknown User,
I'm not sure you are trying to interact with GMail from the browser or from Outlook. If you using a browser: I tried to spy the email's body using Gmail with IE and I was able to identify it uniquely with HTML spy mode, UIA and AA with no problems. I think it depends on your Gmail settings and how the email is displayed.
I copy what InJoe already suggested and strongly recommend to use an email VBO instead of trying to interface the GMail UI: GMail constantly changes their UI and you have no control on that. So even if you manage to automate their UI, most likely your automation will no longer work in a few weeks because Google decided to change the layout.
Luca Valente
Senior Product Consultant
America/New_York
Luca Valente
America/New_York
