CSV Format Issue
maneesh.vemula1
Hi - I have a file that is coming through in a CSV format. The file contains numbers that exceed 15 characters. ex: 43283423423428. This number when saved in a CSV format is being converted to "43283423423420". The ending 8 is replaced with 0. However, while opening with a notepad - the number seems to be correct. Is there workaround or a way to format the data in the CSV so that the last digit won't be a different number. Please let me know. Thanks in advance.
Maneesh Vemula
7 REPLIES 7
vivek.kumar.goel
Level 10
How is that even possible. I haven't seen such issues for a whole number, with fractions, I can stil understand the issue.
How are you opening  the file where you are seeing the issue ? "43283423423420" , is it in Excel?..Can you share some screenshots to provide steps to reproduce the issue?
Vivek Goel
RPA Architect
Asia/Singapore
https://www.rpatools.com/
Hi - Please see image, As you will see the csv file when opened in notepad displays the entire number correctly. But when opened in excel - the last digit is converted to 0. I am using MS Excel VBO (create instance, open, get worksheet as collection(fast)) to retrieve the data. Please let me know if you need any other information. Thanks in advance!
Maneesh Vemula
RPA Specialist
America/New_York
Try using read csv option directly.
Sent from my Samsung Galaxy smartphone.
------Original Message------
Maneesh Vemula
RPA Specialist
America/New_York
The result is still the same - number ending with a 0.
Maneesh Vemula
RPA Specialist
America/New_York
Hi Maneesh,
Please try the below solution and let me know.
https://community.blueprism.com/communities/community-home/digestviewer/viewthread?MessageKey=050166b9-505d-48cc-970d-5e81be6a4b17&CommunityKey=fa047dc0-20a4-4608-af34-ae6578160b33&tab=digestviewer#bm...
Naga
Associate
Hi Naga - I am unable to open the link. Can you please provide the solution here.? Thank You.
Maneesh Vemula
RPA Specialist
America/New_York
TomCirone
This is a documented behaviour in excel
https://www.excelforum.com/excel-programming-vba-macros/704640-csv-number-rounding.html
https://superuser.com/questions/925587/how-to-prevent-excel-to-round-a-number-at-opening
Tom Cirone
Application Developer
Essity
America/New_York
