11-03-20 09:19 PM
12-03-20 12:27 AM
12-03-20 01:23 AM
12-03-20 01:15 PM
12-03-20 01:16 PM
12-03-20 01:28 PM
17-03-20 07:34 PM
Hello Sanjay,
My team and I faced this issue as well and we ended up writing a powershell script to fix this and I would like to offer it to you as it might help but please know that we wrote it for our team and our needs so it is not an official Blue Prism tool and as such has no assurance of support but I think it can help you so please have a look at it.
To make it work you will need two files:
1) The original 6.6 export file
2) The 6.5 (or lower) import file (the one that is all messed up) and to get that just create a new export after you import it and it breaks.
The script should throw up a dialog box and prompt you for both of those bprelease files.
They must be bprelease files and not the .xml files you get if you just do an export.
The script will work with either a process or an object but only one at a time so if your release file contains within it multiple processes and objects you will need to modify the script to handle this but it should be fairly straightforward if you know powershell.
17-03-20 07:36 PM
Hello sir,
I have a response to Mr. Sanjay that might interest you, please feel free to look at it.
Austin
17-03-20 08:34 PM
25-03-20 01:54 PM
