Startup Parameters not enabled for a Process in Studio
Prabhakara_Kuma
Hi, Startup Parameters not enabled for a one of the Process in Studio. Could create a new process and see this option enabled but not for the process which is created some time in the past. Not sure if there are steps to enable startup parameters. Have exposed required parameters as session variables and can see those variables in the control room while process being executed. However, startup parameters screen is not fired up when process initiated for execution and believe not enabling startup parameters is the issue. Would appreciate some tips to work around this issue or a solution if already exists. Thanks
InJoeKhor
Hi  Prabhakara,
Did you confirm your startup parameters are correct and valid (up to date)? Was there an error to indicate the issue ? if it was, what kind of error did the system prompts you when you fail to fire up the start up parameters screen?
Since the process was created sometime in the past, you may want to validate the parameters .This is a very common issue most of us have ran into.
Another tip is to close the extra client you have opened and then restart  the run time(just open a new BP client after closing it).
In Joe Khor
Sr. Product Consultant
In Joe Khor Sr. Product Consultant Blue Prism
InJoeKhor
Hi  Prabhakara,
In Joe Khor
