System Information
MadhuGarg
Hi All,
Is there any option to obtain System Information (Space available in drives, Machine name) using Blue Prism ?
Thanks in advance.
Madhu Garg
6 REPLIES 6
expertcr
We do not have a VBO for this, but you can run a batch file to get this info using the command systeminfo
Luis Lopez
Blue Prism Ltd
Hi @MadhuGarg,
@Luis Lopez has suggested a great way to retrieve all system information using command line command. I can also suggest you a custom VBO which you can build in order to get Machine Name, Total Memory and Memory for individual drives using code stage.
You can create a new business object named 'Utility - System' and add an action called 'Get System Information'​ with a code stage added in the workflow and three data items as shown below:
Here, we have two data items and a collection. Also have these data items mapped to the output arguments in your 'End' stage:
Available Memory (Text) - Gives me the total available virtual memory in the system.
Machine Name (Text) - Gives me the host name of the machine being used.
Drive Status (Collection) - Gives me the size for each of the drives being used.
Now, in the code stage add the following output parameters and code:
Code:
' Initialize Variables
Dim DriveStatusTable As DataTable
Dim DriveStatusRow As DataRow
Dim driveInfo As System.IO.DriveInfo
' Initialize Drive Status Table
DriveStatusTable = New DataTable()
' Add Data Columns To Drive Status Table
DriveStatusTable.Columns.Add("Drive Name",GetType(String))
DriveStatusTable.Columns.Add("Drive Total Size (in bytes)",GetType(Decimal))
DriveStatusTable.Columns.Add("Drive Available Free Size (in bytes)",GetType(Decimal))
Dim drives As String() = System.IO.Directory.GetLogicalDrives()
For Each driveName As String In drives
	' Initialize New Data Row For Drive Status Table
	DriveStatusRow = DriveStatusTable.NewRow()
	'Get Drive Details
	driveInfo = New System.IO.DriveInfo(driveName.ToString())
	DriveStatusRow("Drive Name") = driveName.ToString()
	DriveStatusRow("Drive Total Size (in bytes)") = CDbl(driveInfo.TotalSize)
	DriveStatusRow("Drive Available Free Size (in bytes)") = CDbl(driveInfo.AvailableFreeSpace)
	' Add Data Row To Drive Status Table
	DriveStatusTable.Rows.Add(DriveStatusRow)
Next
'Assign Output Arguments
Drive_Status = DriveStatusTable
Available_Memory = My.Computer.Info.AvailableVirtualMemory
Machine_Name = Environment.MachineName​
Test Results:
Let me know if that helps you out!
WonderBotz India Pvt. Ltd.
Thanks @devneetmohanty07 for detailed explanation. I will definitely follow this & update you.​
Madhu Garg
Hi Devneet Mohanty,  when i tried to run the code stage it throws the following error :
Internal : Could not execute code stage because exception thrown by code stage: The device is not ready.
Could you give a reply asap. I need solution for this asap, Thanks
DILIPKUMAR S
Hi @DILIPKUMAR S ,
You can modify the code a bit which I have provided earlier:
	'Get Drive Details
        If driveInfo.IsReady = True Then
       End If
Next
In the above code, I have added a condition: If driveInfo.IsReady = True Then ...... End If
This will check if the device is ready or not at that time. If yes then only it will execute the inner block statements.
FWIW - There is now a VBO on the Digital Exchange for collecting system information. See the asset page at the following link:
https://digitalexchange.blueprism.com/dx/entry/3439/solution/blue-prism---utility---systeminfo
