System Out of Memory Exception while using Get Reports action
Suresh_KumarMut
Hello everyone,
I am facing an issue in my automation. My Automation will pick PDF from a particular shared drive and combine certain number of PDFs to stitch a book.
Each book approximately have 10 PDFS. Around 750 books has to be stitched in a span of 4 days.
Automation is running successfully for certain period and is failing while using Get Reports action after approximately 50-60 books are stitched.
But it's always failing at Get Reports action only. Below is the error log.
Get Reports Action ERROR: Internal : Unexpected error Invalid value '2020-04-15 18:54:17Z' for a new datetime
Get Reports Action ERROR: Internal : Unexpected error Exception of type 'System.OutOfMemoryException' was thrown.
Get Reports Action ERROR: Internal : Unexpected error Invalid value '2020-04-03 01:26:06Z' for a new datetime
Get Reports Action ERROR: Internal : Unexpected error Invalid value '2020-04-16 13:40:11Z' for a new datetime
Get Reports Action ERROR: Internal : Unexpected error Invalid value '2020-04-15 18:59:37Z' for a new datetime
Preserve Exception Exception ERROR: Internal : Unexpected error Invalid value '2020-04-15 18:59:37Z' for a new datetime
Here BOT has retried 5 time before throwing exception.
The Get Reports action retrieves report from the same folder for every book. It has completed successfully for 50-60 books after then  it's failing.
The folder has around 250 PDFs
Can anyone help me?
Suresh Kumar Muthusamy
5 REPLIES 5
ManasJena
Hi Suresh,
Can you reproduce this and try to monitor CPU and Memory usage while this process is getting executed ?
Manas Jena
Sr Analyst
ZimmerBiomet
America/New_York
Thanks Jena. Appreciate it.
Here is the snapshot of Task Manager while running the Automation.
​Memory is keep on increasing as automation runs over time.
Previous image is unclear. So attaching a clear one
CPU Utilization
Enable the memory logging on the resource and see if you can find where/how the memory is being consumed.
John Carter
Professional Services
