Trigger Process
AdilHussain1
Dear Members,
I need help to trigger process. Below are the details -
1) Scheduler runs and completes the process.
2) After process is completed after some time there are new items are available to be worked on, and scheduler is scheduled to run only once.
3) So is there any way when new items are available after process is completed and something triggers process so those new items when available can be worked on by triggering blue prism to start process ?
Any Help will be appreciated
Adil Hussain
gaunhr
I assume when you said new items are available to be work on, you are referring to Blue Prism WQ items [Please specify where these new items are?]. Instead of having your scheduler run just once, you can schedule it to run in multiple intervals so that process can check constantly for new items to be worked on. Scheduler guide can help you get this sorted.
Narayan Rimal
Fannie Mae
America/New_York
