Trigger Process
AdilHussain1
Dear Members,
I need help to trigger process. Below are the details -
1) Scheduler runs and completes the process.
2) After process is completed after some time there are new items are available to be worked on, and scheduler is scheduled to run only once.
3) So is there any way when new items are available after process is completed and something triggers process so those new items when available can be worked on by triggering blue prism to start process ?
Any Help will be appreciated
Adil Hussain
jegendra
Hi Adil,
Maybe you should consider utilising the concept of Dynamic Scheduler for your requirement.
For further information, please raise a ticket at [email protected].
Jega Avinasinathan
Customer Support Engineer
Jega Avinasinathan
jegendra
Hi Adil,
Jega Avinasinathan
Jega Avinasinathan
SatishPrasad1
​Hi Adil,
Please check the concept of Active Queue... The benefit will be only realised in case you have multiple robots to work upon the case.
Satish Prasad
Senior Analyst Programmer
Fidelity International
Asia/Dili
Hi Adil,
Thanks for sharing!
Just wanted to provide some additional information about Active Queues. You can access this link: https://bpdocs.blueprism.com/bp-7-0/en-us/active-queues.html?Highlight=active%20queue
Lorena Seco de Herrera Ortega
Community Manager
