Unable to add column to Data table using code stage
05-10-16 09:28 PM
Hello Experts,
I want to add a column to existing collection which I am receiving in object's action. To achieve this I have used a Code Stage(C#) which will take collection as input which is internally gets transformed into DataTable. After this I am adding code to insert new DataColumn. However when I compile this code I am receiving error related to DLL. But DLLs and namespace which are required as part of this code is already present.
I have attached a word file describing my code and error.
Note: I have also tried a work around which also failed which is mentioned int the attachment with screen shots.
Can someone please help me out.
Utkarsh Chauhan
05-10-16 10:30 PM
Try Utility - Collection Manipulation.Append Field (Text) or Utility - Collection Manipulation.Append Field (Number)
06-10-16 01:36 PM
Thanks, I will try this out.
06-10-16 05:27 PM
It worked, however I found a root cause why i was getting error when I was writing code in c#.
We need to add ""System.DLL"" as part of external references while writing code in c#. It solved my problem of the errors i was getting.
