Unable to execute PL/SQL Oracle query using oracle client
Using OLEDB object to connect Oracle which done successfully. It is thronging an exception while executing query: ORA-01489: result of string concatenation is too long.   Data Provider is =OraOLEDB.Oracle
Hi, What is the query you're running and what is the output that you are expecting. The error you're getting makes it sound like you're literally getting a string result that is too long. Respectfully, Dave
