Hi Debashis,
There could be following reasons for the above issue:
-Definitely try Michal's advise,this is the first setting which is an issue.If not then try below steps.
- Check Blueprism compatibility by Right click your blueprism desktop Icon>Properties>Compatability tab>change high DPI settings>Check Overide high DPI scaling behavior.and scaling performed by system.
-Another reason could be some websites cannot be scaled on IE so,if using chrome is not an issue try spying on chrome.Refer to my post on spying HTML with chrome,the use of global send keys and clicks is bit different in chrome,which I have explained there.
do let us know how you go.
Gaurav
Gaurav Dhiman
RPA developer,ROM Architect
Melbourne,VIC,Australia
0413 930 960
Gaurav Dhiman
0413 930 960
