26-11-20 08:09 AM
yesterday I tried to process a CSV file. Therefore I use Utility - File Management - Get CSV Text As Collection. It works well so far, but two points strucked me:
- I don't find a way to switch the delimitter. As far as I can see it is only the comma possible. Is there any other way to change the delimitter than swapping characters in the text? My problem is, when I download data from SAP that contains a comma, I choose another delimitter, e.g. tilde. Is there a way to process this data directly without transforming it first. I have already searched in the forum but unfortunately found no approach.
- To prepare the CSV I use a text editor which stores the file in UTF8 format with a BOM. As far as I can see it seems not possible to process the BOM with Get CSV Text As Collection. Can really only ASCII/ANSI files be processed? Or is it also possible to use Unicode directly?
Thanks for answers, hints and tips.
Best regards
Stefan
Stefan Schnell
Senior Systems Engineer at BWI GmbH
26-11-20 02:48 PM
1. two possible ways:
a.
change registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Jet\4.0\Engines\Text
"Format" = "TabDelimited"
or
"Format" = "Delimited(~)"
b.
have a "Schema.ini" file in the source folder with the data:
[your source directory]
Format=Delimited(~)
See for more details on schema.ini files there:
https://docs.microsoft.com/en-us/sql/odbc/microsoft/schema-ini-file-text-file-driver?redirectedfrom=MSDN&view=sql-server-ver15
2. try to add "CharacterSet=65001;" to the connection string in the code (make a copy of action "Get CSV Text As Collection" )
instead of
Dim cn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & Folder & ";Extended Properties=""Text;HDR=" & HDRString & ";FMT=Delimited;""")
use
Dim cn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & Folder & ";Extended Properties=""Text;HDR=" & HDRString & ";FMT=Delimited;CharacterSet=65001;""")
see if data are correctly taken as UTF-8
Mindaugas Breskus
Software engineer
Swedbank
Europe/Vilnius
26-11-20 02:48 PM
a.
or
b.
Format=Delimited(~)
instead of
use
Mindaugas Breskus
Software engineer
Swedbank
Europe/Vilnius
30-11-20 08:44 AM
Hello Mindaugas,
thank you very much for your interesting answers.
I will try that.
Best regards
Stefan
Stefan Schnell
