Hi
Asitabha,
You cannot copy and paste direct macro code in blue prism code stage.
1.In VBA you can use "let" Or "set" to set any object but if you do copy paste blue prism never permit use let or set.
2.Set is very important in VBA.using this word you can set as file,range,sheet,application or object
3.Blue prism is never recognize very basic vba words and commands like "createobject".
4.You have to know about dll and same dll you should use in vba so you can just mention that dll name along with path ( use path if required )
5.you have to use namespace in Blueprism which you can find on google.
I hope it help.
Nilesh
Nilesh Jadhav
Senior RPA Specialist
Nilesh Jadhav.
Consultant
ADP,India
