Work with Excel
Hi, How to work with Excel file? I mean modifying the file,such as adding borders, changing font etc. Are there particular VBOs used for it? Thanks P.K.
TomBlackburn1
Level 7
All, I'm no expert at VB, but the below should work. For the border actions, you could of course pass in a input for line style and weight and make the decision as to what to apply. But the below just uses a static value. ================= COLORS ================= INPUTS ================= Handle [Number] (e.g. 1) Workbook[Text] (e.g. ""myspreadsheet.xlsx"") Worksheet [Text] (e.g. ""sheet1"") myrange [Text] (e.g. ""A1:F8"") r [Number] (e.g. 100) g [Number] (e.g. 100) b [Number] (e.g. 100) ================ CODE ================ Dim wb, ws As Object Dim excel, sheet As Object wb = GetWorkbook(Handle, Workbook) ws = GetWorksheet(Handle, Workbook, Worksheet) wb.Activate() ws.Activate() excel = ws.Application sheet = excel.ActiveSheet ws.Range(myrange).Interior.Color = RGB(r,g,b) =========== BORDERS - Around a range (excluding internal borders) =========== INPUTS ================= Handle [Number] (e.g. 1) Workbook[Text] (e.g. ""myspreadsheet.xlsx"") Worksheet [Text] (e.g. ""sheet1"") myrange [Text] (e.g. ""A1:F8"") r [Number] (e.g. 100) g [Number] (e.g. 100) b [Number] (e.g. 100) ================ CODE ================ Dim wb, ws As Object Dim excel, sheet As Object wb = GetWorkbook(Handle, Workbook) ws = GetWorksheet(Handle, Workbook, Worksheet) wb.Activate() ws.Activate() excel = ws.Application sheet = excel.ActiveSheet Const xlContinuous = 1 Const xlThick = 4 Const xlSuperThin = 1 Const xlThin = 2 Const xlMedium = 3 ws.Range(myrange).BorderAround(LineStyle:=xlContinuous, Weight:=xlThin, color:=RGB(r,g,b)) =========== BORDERS - Around a range (including internal borders) =========== INPUTS ================= Handle [Number] (e.g. 1) Workbook[Text] (e.g. ""myspreadsheet.xlsx"") Worksheet [Text] (e.g. ""sheet1"") myrange [Text] (e.g. ""A1:F8"") r [Number] (e.g. 100) g [Number] (e.g. 100) b [Number] (e.g. 100) ================ CODE ================ Dim wb, ws As Object Dim excel, sheet As Object wb = GetWorkbook(Handle, Workbook) ws = GetWorksheet(Handle, Workbook, Worksheet) wb.Activate() ws.Activate() excel = ws.Application sheet = excel.ActiveSheet Const xlContinuous = 1 Const xlThick = 4 Const xlSuperThin = 1 Const xlThin = 2 Const xlMedium = 3 Dim rng =ws.Range(myrange) With rng.Borders .LineStyle = xlContinuous .Color = RGB(r,g,b) .Weight = xlThin End With
