Hi
@NakkalaBharathFor this, you need to know the char index of the search character.
You need to use the VBO "Utility - Strings" with the Action "InStrRev". This actions gives you the position of the search text.
If the position is greater than 0, means that the search text was found in the original text.
The structure looks like this:
Hope this helps you!!
See you in the Community, bye
Pablo Sarabia
Solution Manager & Architect
Altamira Assets Management
Madrid
