importing releasefile using AutomateC
Sudharsana_RaoT
Hi,   I have a release a file in my local desktop, is there any CMD command which can import this release file into a dbconname. I need help on the following command from CMD, AutomateC /sso /dbconname="conName" /import "releaseName" I am getting error like "......root element id it should be " Is there any way that I can import whole release in a BP environment rather importing a process.   Thanks and Regards, sudharsan.
12 REPLIES 12
david.l.morris
Level 15
Check the documentation on command line options again. You want /importrelease not /import.
AndrzejKaczor
Hi David, would you be so kind to pint me to the direction of that documentation? I spent 10 minutes searching for that and couldn't find it anywhere here.   Thanks Andrzej
david.l.morris
Level 15
Hi Andrzej, In Blue Prism, hit F1 (or click ? at the top right) and in the Search tab, search for ""command line"". Then you can use CTRL+F on the page to find importrelease. Respectfully, Dave
Sudharsana_RaoT
Hi Dave, I am lookin for CMD line command, not from BluePrism client wizard. Thanks, Sudharsan
AlexanderSuckow
Hi,   you can find this info in the F1-Help under ""Advanced Topcis"" and ""Command Line Options"".   Best regards
Uday__Arikatla
Release import is successfully from command prompt in Blue Prism v6 with AutomateC /sso /dbconname=""conName"" /import ""releaseName"" But Release import is failing from command prompt in Blue Prism v5.0.35 Need help with release import from command prompt in Blue Prims v5.0.35
david.l.morris
Level 15
/importrelease not /import /importrelease is for .bprelease files which is a grouping of BP components such as objects or processes /import is for individual objects or processes that need to be imported individually
Sujan_ReddyJill
What options do I have to import a bprelease file with SSO disabled(due to company policy)?
david.l.morris
Level 15
You don't have to use SSO. The examples that were mentioned here are simply because most organizations use SSO. In the same place that you see '/sso', you just use the username and password options like this: /user AutomateC /user yourBPUsername yourBPPassword /dbconname=""connection name here"" /importrelease ""release path here
