issue in code stage using C#
maryamAshkar
Since C# code stage of blue prism cannot detect the List exactly, we preferred to try DataTable with the DLL's and namespaces of
System, System.Data.dll, System.Xml.dll, System.Drawing.dll,
System, System.Data,  System.Drawing, System.Collections.Generic
. The code is:
DataTable dt = input;
Result=dt;
However, we have the problem of:
Description: Compiler error at line 2: The name 'input' does not exist in the current context, while I have created it in input part of code stage.
I would be grateful if someone can help me.
Thanks in advance
hi Maryam,
Did you created  data table "input" and pass in to the  code stage input parameter?
Harish Mogulluri
in other words, create input parameter collection and give the parameter name "input".
That should fix it.
Zdenek
