08-06-20 12:21 PM
I have an application server, a runtime, and a client maschine (all VMs). Since today 9 AM everything worked normal.
1. I scheduled a process from the client to run on the runtime. It run normally.
2. I made a little change on two VBOs the previously started process uses and tested them with the 'personal runtime' on client. All fine.
3. I wanted to schedule the process (as in step 1) and got the error "Not Connected "XXXX" can't start process"
When I schedule the process form runtime to run on runtime - it works.
When I want to start the scheduled process (from runtime) from client - the same error "Not Connected "XXXX" can't start process"
I rebooted all maschines several times.
I tested the TCP connection from client to runtime and appserver - all fine.
Please help.
15-06-20 08:42 AM
15-06-20 12:39 PM
