JosephSteegan
Status: Delivered
This is a feature of the product.
The AD Group for the System Administrator is set during the creation of the Blue Prism database and cannot be modified at a later stage.
Proposal:
If you add feature to allow for the AD group for System Administrator to be changed after the initial configuration.
2 Comments
You can do that, here where you can do it.
*IMPORTANT NOTE* If the user is not a member of both groups, it can leave himself locked out of the environment.
System / Security / Sign-on Settings
Status changed to: Delivered
Hello @JosephSteegan,
Thanks for taking the time for raising an idea.
From Blue Prism Enterprise 7.1 onwards, users are able to edit the security group assigned to the administrator role in Blue Prism in additional to all other roles.
Based on this update, I'm going to mark this idea as Delivered.
Rob
