I would appreciate the possibility to add notes to a process or object directly in Studio.
The reason for my request is that when you are maintaining a process or object, you might observe issues that you cannot address directly but would like to write down for the next development opportunity.
Possible solution:
You would right-Click on the process or object in Studio, chose option 'Add Note' and write your comment, click Ok button to save.
