Many times when calling a service, the wsdl used to configure the client call and the eventual endpoint for the call are different. In these cases, we should be able to override the endpoint. In Blue Prism, the endpoint in the wsdl used in configuring the SOAP Web Service is what is used and there is no way to change it. We would like an option to Override the endpoint on a SOAP Web Service.
