Problem Statement
Currently, when configuring Web APIs that use OAuth 2.0 Client Credentials authentication, the Token URL (Authorization URI) endpoint cannot be configured using a variable. While other settings, such as the Base URL, support the use of variables, the Token URL requires a static value.
Although it was indicated that this functionality works in version 7.2, testing has shown that the same limitation still exists as in NextGen. Attempts to use a variable for the Authorization URI result in validation or runtime errors.
Business Impact
Requested Enhancement
Allow the Token URL / Authorization URI used for OAuth 2.0 Client Credentials authentication to be configured through an environment variable, in the same manner as Base URLs and other endpoint settings.
Expected Benefits
Current Workaround Administrators must manually update the Token URL for each environment or maintain separate configurations, which increases operational overhead and risk.
