ritansh.jatwani
Level 9
Status: Not Planned
During the design of any process, there are various instances when the blue prism reports lots of errors which are very small errors and can be auto-corrected by Blue Prism such as the stage is only partially within a block, stage to store in the result doesn't exist etc. The Blue Prism should throw a popup asking the user if he/she wants to auto-correct some of the errors errors by itself or not. This feature will help be very useful in resolving majority of the errors and saves the developer's time.
1 Comment
Status changed to: Not Planned
Hi @ritansh.jatwani,
Thanks for taking the time to raise an idea.
At this time, the number of upvotes (2) from the community at large seems to indicate that most users would not find the pop-ups suggested a useful enhancement to Design Studio, instead deciding to review errors at a time of their choice by opening up the Validation Log.
I'm going to update this idea to Not Planned for now. Users would still be able to vote on the item should the decide this feature would be useful, so I'd be happy to revisit this in future if there is a significant change in the level of support expressed for this.
Rob
