ritansh.jatwani
Level 9
Status: New
During the design of any process, there are various instances when the blue prism reports lots of errors which are very small errors and can be auto-corrected by Blue Prism such as the stage is only partially within a block, stage to store in the result doesn't exist etc. The Blue Prism should throw a popup asking the user if he/she wants to auto-correct some of the errors errors by itself or not. This feature will help be very useful in resolving majority of the errors and saves the developer's time.
