majateblue85
Status: New
When building, fixing or adding to a process/object you will add data items/collections to what you are doing - it can then become a task to bring together/tidy and organise this.
My idea is to add an auto sort button would allow these to pull together automatically - allowing you to organise further from there. This will save time and become a lot easier to manage.
1 Comment
This saves time during development and debugging, improves the readability, sorting alphabetically or by the usuage frequency, group/filter by data types: text, number etc etc.
But on the other side if there’s no clear undo or history feature, reverting an unwanted auto-sort could be tedious and if the sorting logic isn’t customizable, it might group or sort items in a way that doesn’t align with the developer’s intent  and it may complicate version control with unnecessary structural changes. But the idea of having a SORT Button helps but UNDO Button should also be there.
