Noticed a major difference regarding saving in BluePrism 6.9
Suddenly after saving, all my active data is removed, basically performing a full process reset, which never happened before.
That is in my opinion a very bad idea as I myself like to save after every confirmed functional change, thus forcing me to either not save or to redo the actions if I am debugging something or developing actively.
Is this saving behavior intentional?
