SabinRavi
- Mark as Read
- Printer Friendly Page
11-11-21
12:15 PM
Status:
Under Consideration
- Auto classify and Auto verify - this feature should be controllable in terms of batch type or at document definition level, controlling this at the global level means no sense unless we are using decipher just for one process
- Table delimiter - there should be an option to define the table delimiter so that unwanted information (in cases where there is two tables this is causing issues)
- When using Exclude value option, I could see that it seems to check whether that word exits in the sentence rather than exact match. Will be great if that can be configured to take exact text or option for both
- In terms of development, one of the main trouble is not being able to add a file and test it out, if adding a sample file and testing it out in preview is added that will really help in terms of development.
- Since blue prism is not having a VBO out of the box to handle pdf, including a method to define the specific page from which the data has to be extracted will avoid unnecessary pages being processed.
- The ability to use Classification and extraction as combined as well as individual modules, will help a long way . (so the process which requires classifying documents alone can also use decipher for the same)
