- Mark as Read
- Printer Friendly Page
01-08-22
05:34 PM
Status:
Reviewed
Currently, when setting an LOB value in a process design create web service, a configuration is required to set the value to the max character length of the LOB field. If this is not done, and the value is longer than the max length defined for that LOB field, the service will fail. The design tool should be enhanced to automatically truncate the value to whatever the max length is for the LOB field, so this design configuration is not always required.
2 Comments
