- Mark as Read
- Printer Friendly Page
Enhancement request to have the ability for the system to tell you if the user being disabled is an owner of a case like it does with work in the worklist. Product Management provided the following feedback as to enhancements in the works:
We have User Admin requirements in play right now and this use case has not been addressed yet.
User Admin is undergoing enhancements to support the ability to DEACTIVATE a user ... which is different than just disabling their status.
Today, disabled is both a temporary and a permanent availability status.
When you intentionally disable somebody ... it is because you want to take away permissions (security, privileges, configurations for various teams - like a case team). We check today to handle assigned work. We don't check on any memberships anywhere else. This is a good use case.
