BhagavathsinghR
- Mark as Read
- Printer Friendly Page
07-11-19
05:41 PM
Status:
Not Planned
Issue:
*Runtime Resource Blueprism Listener is facing out of memory exception when the listener memory exceeds 1.5 GB.
*The memory of the Listener is increasing because of the runtime resource logs.
*Since the Logs include connection logs of all the runtime resources listening to same server
Ref Tkt Number : 75620
Solution:
* Disable/Enable option for the runtime connection logs
* Utility or command to release the log memory remotely.
See more ideas labeled with:
5 Comments
