It would be beneficial to set a Lock release time on environment locks. As an example, you set 5 minutes, if after that time the lock hasn't been released the system will unlock it.
This would help in instances where the process may freeze while performing actions and the lock then never gets released unless you manually do it in the system settings or the running resource is rebooted.
