MikkoKamppila
Status: New
Currently, to autoincrement a counter variable that adds +1 (typically) on every loop round, a separate calculation stage is needed plus a variable to hold a counter data.
My suggestion is to integrate
  • autoincrement function into a loop (checkbox to trigger the feature on/off per loop)
  • in case autoincrement functionality is used
    • a placeholder for a name of counter variable (datatype : number)
    • button next the counter variable name to create a stage that holds counter variable
    • a placeholder for a base value (typically 0 or 1)
This is mostly a QoL enhancement.
