Spy modes needs to improve for browser automation also a tree structure should appear for these as well.
After spying any element we are getting set of attributes. But we don't know about lot of attributes how and where to use. But in other way way it may be more helpful if we can get guide for that. It may make our automation easier.
For Example we can use real X path in Browser automation but it's nowhere mentioned. At the same time it can make easy for th all the automation.
Also I found some useful options are not available in chrome automation (Browser mode), which is very helpful. At the same time all the options are available in HTML mode.
