Roberto_WilniSu
Status: Needs More Info
We would like to have the 'Retired' functionality extended to Work Queues and/or Queue Management.
When processes are retired, work queues associated to them still appear in Queue Management and the Control Room.  This provides a less than ideal user experience as users now have to manage queues that are no longer in use as well as active queues.  This also poses an additional problem as RPA scales - the Queue Management and/or Control Room will continue to look busier without the ability to retire queues.
2 Comments
vivek.kumar.goel
Level 10
Queues concept also help in reporting. Hence it's intentional not to remove the queue when the associated process is retired (Active Queue case). I would like the queue to be stopped atleast when the associated process is retired.
For normal queues, it's not necessary for 1 queue to be used/accessed by 1 process only. Hence the idea can't be implemented in this case .
Hello @Roberto_WilniSu,
Thanks for taking the time to raise an idea.
I'm wondering whether an "Inactive" flag against each work queue which, when enabled, would hide the queue from view would be acceptable an acceptable alternative to an entirely new retired queues screen and all the mechanisms that come with that?
I'm going to mark this idea as Needs More Info awaiting your feedback.
Rob
