vgarciaa
Depending on the screenshot and the resolution of the computer, the screenshot may be too small. Adding an option to zoom it helps when the user needs to censor items on screen. Lots of customers still use screens that are 1366x768 and zoom helps in those scenarios
Also, it would be great to have the ability to disconnect arrows and reconnect them. Including the option to delete decision points without deleting the corresponding branches.
