SameerJoshi1
Status: New
Thinking of base excel VBO, which stores only instance information. And this excel VBO can be inherited to accommodate more functionality.
2 Comments
AndreyKudinov
Level 10
Correct me if I'm wrong, but inheritance won't work here, because you won't be able to pass COM object references between VBOs.
What can be done is having common core VBO + extended actions developed/posted separately, which you can pick up/update one by one and insert into a core.
I was thinking about implementing this idea, but didnt find spare time for it yet.
SameerJoshi1
You may be right here. The problem I was trying to solve was - whenever you need to extend excel functionalities, you need to create copy of BP's excel VBO and then need to add actions into it. Which ends up creating too may excel objects.
