Control Room Terminating Process
23-03-20 05:50 PM
I have been working through the Blue Prism Foundation Training. I am almost complete with the Consolidation exercise. I am at step 1.1.16. I have the process configured to run in the control room. When I go to run the process, it will run to the Load Orders actions and then terminates with the following error.
Thank you,
Sherri Henderson
ERROR: Internal : Could not execute code stage because exception thrown by code stage: Call was rejected by callee. (Exception from HRESULT: 0x80010001 (RPC_E_CALL_REJECTED))
When I run the process manually in the Process Objects Studio, it runs fine. Could this be a security error trying to get to my orders.csv file?
Thank you,
Sherri Henderson
23-03-20 08:44 PM
Hi Sherri,
This issue is caused when Excel is busy when trying to access it. Check if there are any open dialog boxes. You can also try a sleep stage before the Excel action/stage. You can also see if the orders.csv file is not already open.
Hope this helps.
Alexander Marlowe
Hope this helps.
Alexander Marlowe
25-03-20 05:38 PM
Alexander,
Thank you this was the issue.
Sherri Henderson
Sherri Henderson
25-03-20 05:56 PM
I'm glad it worked, Sherri!
Alexander Marlowe
Alexander Marlowe
