Microsoft Edge - Browser extension was not detected
Sakthini03
I am working on one of the automation process to automate a browser based application using Edge. I am getting following error message while launching the application:
Internal : Failed to perform step 1 in Navigate Stage 'Launch' on page 'Launch' - The browser extension was not detected, please check that it has been installed and enabled. For more information, see the browser extension user guide. https://bpdocs.blueprism.com/bp-6-10/en-us/Guides/chrome-firefox/chrome-firefox.htm.
I have tried multiple ways to resolve the issue like,
Eventhough i facing same issue. Please help me with the issue.
Sakthivel S
Sakthivel S
HI Sakthivel,
There are couple of workaround to fix this issue
Check below thread from Blue Prism Support center related to this issue. on top of that  it depends on how you close the application and launch the application as well
Add retry logic to avoid this issue if you are closing the browser using kill process then try to close the application using close action in object . also after closing wait for few seconds before launching application,
After launching the site  you need to select customer login> use the same credential as BP portal
https://support.blueprism.com/en/support/solutions/articles/7000076733-bpe-error-the-browser-extension-was-not-detected-when-attempting-to-launch-a-browser-based-chrome-
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
HI Sakthivel,
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
Thanks for the solution.
I will try that from my end.
Sakthivel S
