a month ago
Hi team,
I am performing one step where i need to focus & then click on a hyperlink which is a form name. I have spied it using attributes -
1-UIA Name - name of the form which is unique( Match type-Dynamic )
2-UIA Localized Control Type - Link
3-UIA Control Type - Hyperlink
4-Match Index - 1
This spying sometimes works & sometimes not. Sometimes I am NOT able to highlight the element, but if i create new element using same attributes, i am only able to highlight new element & not the old one. Does anyone know what's the reason behind this inconsistancy & can anyone suggest something please. Your help is much appreciated.
a month ago
Did you try using this application navigator option in application modeller
3 weeks ago
Hi Sapna,
If you noticed inconsistencey to identify certain hyperlink
I would probably try detach and attach the application before identifying this action Also I would try different attribute selection and if the first element performing anaction is failing i would try second elements spied in app modeller.
