Edge Extension Issu
EricLi1
Our Blue Prism is 6.10.4. Installed Blue Prism 6.10.4 edge extension, but error message as below pop up when create edge object. What shall I do?
"Error - Failed to launch application - The browser extension was not detected, please check that it has been installed and enabled. For more information, see the browser extension user guide."
Eric Li
Operation Analysis
AIG
Asia/Hong_Kong
lookman
Hi Eric.
Are you using Ephemeral Ports? There was an issue in an earlier version of BP although I assume it has been resolved by 6.10.4 but am not certain.
Anyway, if you are not using them, give it a try to see if it help resolve this issue.
jack
Jack Look
Sr Product Consultant
bruce.liu
Hi Eric,
Please take a look at the following KB article:
https://portal.blueprism.com/customer-support/support-center#/path/Automation-Design/Application-Integration/Browser/1811780012/Why-do-I-get-error-The-browser-extension-was-not-detected-when-attemptin...
If it does not help you, please kindly raise a support ticket with us.
Bruce Liu
Australia/Sydney
