09-03-23 05:27 PM
Hi team,
I'm facing the below error while trying to copy a worksheet from one workbook to another workbook. I'm using the latest MS Excel VBO from DX.
I'm passing True in Copy flag since the action name says Move Worksheet but also has a flag exposed to only copy(should rename this action to Move/Copy Worksheet)
I have both workbooks opened.
Tried different scenarios here but could not find a solution to this error.
Any help would be appreciated.
09-03-23 07:36 PM
Additionally I did try with the most latest version I could find out from DX with download link as : https://digitalexchange.blueprism.com/dx/entry/3439/solution/ms-excel-vbo, and I was able to move the worksheet with this VBO as well.
You should pass the Destination Position as 1 as index starts from 1 in MS Excel (Ref - Sheet1 by default), let me know if you face the error again !! with these changes.
09-03-23 07:19 PM
Hello @Tejaskumar_Darji - I have tried replicating that with one of my extended actions in MS Excel VBO Extended object - I was able to move sheet at said index from source Excel workbook to the primary Excel workbook.
I have attached the release alongside for object just check if you can see and compare with your own MS Excel VBO, let me know if you face any difficulties in executing it.
09-03-23 07:36 PM
13-03-23 10:06 AM
It got finally resolved. The issue was with the way I was opening the other PDF. I was creating 2 separate handles and opening both excel individually before doing copy worksheet but after seeing your snapshot I directly opened another workbook in the same handle. Now able to copy worksheets.
Thanks @Mukesh Kumar
